Travel & transport from BBC stories as at 21:55 25 Apr 2024
- Will Labour’s renationalisation plan make train tickets cheaper?
* Rail Britannia?
- Will Labour’s plan make train tickets cheaper?
- Labour pledges to renationalise most rail services
17/08/24 - Bus to Imber
27/09/25 - 200 years of passenger trains
No 'On This Day' events reported for 25th Apr
April 25, 2024, 22:10:36 *
[219] Labour to nationalise railways within five years of coming to ...
[56] access for all at Devon stations report
[39] Lack of rolling stock due to attacks on shipping in the Red Se...
[26] Cornish delays
[25] Theft from Severn Valley Railway
[14] Where have I been?
Author Topic: Derailment at Paddington - 25 May 14  (Read 16362 times)
« on: May 25, 2014, 10:43:39 »
An empty Heathrow Connect train has partially de-railed at London Paddington.
Happened at platform 3 with a unit coming in from the depot.  One coach has derailed.  RAIB (Rail Accident Investigation Branch) on scene investigating.
Not causing any problems to other services.
tom m
« Reply #1 on: May 25, 2014, 13:11:42 »
Picture up on twitter:
https://twitter.com/FreddieNathan/status/470515483276767232/photo/1
johoare
« Reply #2 on: May 26, 2014, 00:07:05 »
A strange platform for a Heathrow train?
« Reply #3 on: May 26, 2014, 00:51:55 »
The unit derailed was actually the sole Heathrow Express Class 360 (360205). Usually to be found shuttling back and forth between the Heathrow Central and Terminal 4 stations.
Couple more pictures:
https://twitter.com/ConnieforLondon/status/470571317813870592
https://twitter.com/JohnWomersley/status/470541844645183488
"Build a man a fire and he'll be warm for the rest of the day. Set a man on fire and he'll be warm for the rest of his life."
- Sir Terry Pratchett.
a-driver
« Reply #4 on: May 26, 2014, 08:19:28 »
It was an early morning ECS (Empty Coaching Stock) move from the depot.  At that time of the morning (and late evenings) they will generally use of any of the wired platforms as they sometimes arrive from the depot as a 10-car.
« Reply #5 on: May 26, 2014, 08:26:59 »
There are new longitudinal timbers laying in the 6 foot, just wonder if there was a know problem with the ones supporting the rails and were down to be replaced
« Reply #6 on: June 12, 2014, 13:15:43 »
From the RAIB (Rail Accident Investigation Branch):
Derailment at London Paddington station 25 May 2014
RAIB is investigating a derailment that occurred at London Paddington main line station, on Sunday 25 May 2014.
The train that derailed was an empty five car Class 360/2 passenger train (reporting number 5T08), manufactured by Siemens and operated by Heathrow Express. It was travelling from Old Oak Common to Paddington in preparation for entering passenger service.
At 05:20 hrs, both sets of wheels on the leading bogie of the third vehicle derailed to the left when the vehicle was about 150 metres from the buffer stops in platform 3 and travelling at between 12 and 14 mph (19.3 and 22.5 km/h).
The driver twice stopped the train after it derailed. On both occasions, unaware of what had happened, he restarted the train. As a consequence, the train ran nearly 100 metres in a derailed state and was finally stopped with the right side of the derailed bogie in a pit that was located between the rails, which lifted both wheels on the left side of the rear bogie off the rails. No one was injured.
Platform 3 remained closed for the remainder of the day.
RAIB^s investigation will examine the sequence of events leading up to the derailment and will seek to identify the causes. This will include consideration of the design, maintenance and condition of both the track and the derailed vehicle. The RAIB^s investigation is independent of any investigation by the safety authority (the Office of Railway Regulation).
RAIB^s investigation is independent of any investigation by the Office of Rail Regulation.
RAIB will publish its findings, including any recommendations to improve safety, at the conclusion of its investigation. These findings will be available on the RAIB website.
« Reply #7 on: June 12, 2014, 13:32:15 »
Who's gonna bet that one of the recommendations will be for a driver to have to visually inspect the whole train to make sure it's not partially derailed whenever he/she feels a sudden snatch or loss of power?   Undecided
chrisr_75
« Reply #8 on: June 12, 2014, 13:57:14 »
I feel sorry for the poor sods who had to re-rail that train - the cr@p in the 4 foot on those platform roads occupied by HST (High Speed Train)'s is appalling.
Thatcham Crossing
« Reply #9 on: June 12, 2014, 17:07:47 »
Noticed what I think was this unit parked-up at OOC (Old Oak Common (depot)) when I went past today.
« Reply #10 on: May 29, 2015, 15:16:49 »
The RAIB (Rail Accident Investigation Branch) has released its report into this incident:
At around 05:20 hrs on Sunday 25 May 2014, the third vehicle of an empty five car class 360/2 passenger train manufactured by Siemens and operated by Heathrow Express derailed while it was running along platform 3 at London Paddington station. All four wheels on the leading bogie of the third vehicle became derailed on a track defect which, according to Network Rail^s standards, required a repair within 36 hours. No one was injured as a result of the derailment.
The derailment occurred because the bogies of the third vehicle were incorrectly set up, which resulted in the left-hand wheels of the leading bogie being partially unloaded even when stationary. The track defect along platform 3 exacerbated this unloading and contributed to the derailment.
The investigation has found that the incorrect setup was the result of the repeated implementation by Siemens technicians of a procedure aimed at setting the vehicle ride heights following tyre turning or bogie replacement. This procedure did not clearly instruct the technicians on how to adjust one of the bogie components (the anti-roll bar) which resulted in the technicians setting it in such a way as to create the wheel load imbalance. None of the checks in the procedure identified the incorrect setup because these checks were not monitoring parameters likely to provide a clear indication of a wheel load imbalance. An underlying factor was the lack of effective transfer of design information about the role and importance of the anti-roll bars between the vehicle designers (Siemens Germany) and the vehicle maintainers (Siemens UK (United Kingdom)).
The track defect had been repeatedly identified by Network Rail^s measurements of track geometry for at least three years. However the required processes to remedy the defect were not followed and this was not picked up by Network Rail^s assurance process.
As a result of this investigation, the RAIB has made four recommendations to Siemens and one to Network Rail. The recommendations to Siemens relate to the revision of the procedure used to set the vehicle ride heights, training materials and competence assessments to capture the function of anti-roll bars, their method of adjustment and the risks associated with incorrect setup. The recommendations also cover a review of other maintenance procedures and a review of the effectiveness of Siemens^ recently developed processes for transfer of design information into maintenance procedures.
The recommendation on Network Rail is to review its supervision and self-assurance arrangements to identify shortcomings which led to the non-compliances with a mandated standard going unnoticed.
Full report: https://assets.digital.cabinet-office.gov.uk/media/5540a1bced915d15db000048/150430_R032015_Paddington.pdf
onthecushions
« Reply #11 on: May 30, 2015, 13:43:39 »
A very fortunate track defect. Imagine that bogie coming adrift at speed.
OTC
