Travel & transport from BBC stories as at 08:35 25 Apr 2024
* Labour pledges to renationalise most rail services within five years
- The Papers: Labour 'vow to nationalise rail' and school stabbing
17/08/24 - Bus to Imber
27/09/25 - 200 years of passenger trains
No 'On This Day' events reported for 25th Apr
08:35 Banbury to Didcot Parkway
06:30 London Paddington to Cheltenham Spa
06:44 Exeter St Davids to Cardiff Central
An additional train service has been planned to operate as shown 08:49 Plymouth to Cardiff Central
April 25, 2024, 08:48:16 *
[163] Lack of rolling stock due to attacks on shipping in the Red Se...
[105] Theft from Severn Valley Railway
[59] Where have I been?
[58] 2024 - Service update and amendment log, Swindon <-> Westbury...
[56] Labour to nationalise railways within five years of coming to ...
[49] Death of another bus station?
Pages: 1 ... 7 8 [9] 10 11 ... 13
Author Topic: The end of coal  (Read 35751 times)
« Reply #120 on: July 16, 2021, 08:18:40 »
Here's a thought why not use the sites for geothermal,after all there's a fair amount of water already present ,and a good deal of the drilling has been done for you,I'm thinking something along the lines of what's happening at the Eden Project in Cornwall.
The heat in the "hot rocks" being exploited in Cornwall is found in granite. Coal is formed by peat being compressed by sediments, so the ground is much softer and a lot cooler. The temperature of the water in an abandoned coal mine is around 16°C. Although warm enough to be of benefit in a heating system, because warming water from 16°C to 50°C takes a lot less energy than starting at 4°C, you can't make electricity directly from it. In the hot granite in Cornwall, the temperature of the water is around 180°C. The steam can be used directly to power turbines, or through heat exchangers to heat water to above boiling point. The cooler waste water can be fed to zonal heating systems, as is proposed in Cornwall, or pumped back underground to heat up again.
The heat in the hot rocks comes mainly from radioactive decay. The Cornish hot water contains much higher concentrations of Thorium than are found elsewhere, although not sufficiently high as to be harmful in normal circumstances. I believe the drilling has found aquifers, but "dry" rocks can be exploited by pumping water into boreholes at sufficient pressure to form cracks.
Don't say it too loudly - this is nuclear energy, that could be exploited on a much wider scale by fracking.
« Reply #121 on: November 04, 2021, 21:04:21 »
Government confirms that the environment bill will not apply to steam trains.
According to Railadvent it's not just steam locomotives but heritage engines in general.
https://www.railadvent.co.uk/2021/11/government-confirms-environment-bill-will-not-apply-to-steam-locomotives.html
« Reply #122 on: November 05, 2021, 01:22:34 »
Good.
I am opposed to large scale coal burning for power generation, and the UK (United Kingdom) has ALREADY greatly reduced coal burning in power stations.
I would support limited coal burning for heritage or historical purposes. Since this is ungreen, I would hope that heritage railways and other heritage coal users would be as green as possible in other respects.
« Reply #123 on: November 05, 2021, 07:58:09 »
But once the heat pump is in you get far more heating (or cooling, depending which way it's running at the time) than the amount of power put into the pump. If you can run that pump off PV or wind or whatever's green at the time, you get more heat for your kilowatt than using that electricity directly for heating.
Yes correct.  A near surface ground source heat pump (without any significant geothermal energy) used for domestic heating typically has a Coefficient of Performance (COP) of 4 which means that it will typically produce 4 times more heat than the electricity put in. The amount of electricity required depends on the temperature increase you require so if there is some geothermal energy it would increase the COP but increasing the output temperature will decrease the COP.
The COP of an air source heat pump is typically 3.
« Reply #124 on: November 05, 2021, 12:34:35 »
A family member is about to start building a house, and looking into the different options. He has the luxury of a blank canvas within a field. It seems ground source is better, but more expensive - is this right?
PhilWakely
« Reply #125 on: November 05, 2021, 12:39:12 »
A ground source installation is somewhat more complicated, requiring pipes to be buried underground. See here
« Reply #126 on: November 05, 2021, 14:24:05 »
Yes and it will normally require a more space than the average garden for the pipes.  More suited to a rural location than a town.  Unless you want to go for a borehole in which case it is even more complicated.
« Reply #127 on: November 05, 2021, 14:32:44 »
For a new house, I would favour great thermal mass and excellent insulation, together with MVHR. Such a house will need no heating in average winter weather, and only a very little heating in severe weather.
This very small heating demand is affordably met from direct electric heating.
In such a home I would install a small solid fuel stove, unlikely to be much used, but most useful to have in case electricity becomes unavailable for an extended period.
Grid tied PV to reduce electricity bills.
A small battery charging PV system to supply limited emergency power in case mains electricity becomes unavailable for an extended time.
Cooking all electric normally, but perhaps a small LPG (Liquefied Petroleum Gas) hob in addition, with gas bottles in a safe external store.
« Reply #128 on: November 06, 2021, 00:23:18 »
Thank you both - interesting reading material. Definitely rural, and a borehole will be in place for water. That means that some drilling kit will be in situ, which could cut the cost a fair bit. The installation within the house will be the same, so I think I will look at the difference in cost versus difference in running costs. My role does not extend to decision making, but such information as is around tends to be either too generic or aimed at a particular answer.
« Reply #129 on: November 06, 2021, 05:16:36 »
The advantage of substantial thermal mass and extreme insulation, is that there is very little to go wrong.
Heat pumps are expensive to buy, may need costly repairs and consume significant electricity.
An extremely well insulated home will need NO heating in average winter weather, and only a little heating in severe weather.
MVHR adds complexity, but not as bad as a heat pump, and reduces energy use still further.
A super insulated home is immune to SHORT power cuts, it should remain comfortable for a few hours, and tolerable for up to 24 hours.
I therefore recommend a small solid fuel stove in case of any prolonged power outage. This should see very little use and is not the main heat source. It could however save your life if the power goes out for a week or more in a severe winter.
For similar reasons I would recommend  a small battery charging PV system, not worthwhile in strict financial terms, but could be most important in an emergency. A single 300 watt PV module and a couple of 12 volt deep cycle batteries would serve. That would provide for limited essential lighting, and low power portable electronics in an emergency.
« Reply #130 on: January 12, 2022, 16:37:01 »
The "ban" on retail sales of house coal is now in effect with little effect. The ban only applies to "pre-packed" house coal and is generally evaded by sales in open bags rather than in sealed bags.
Most petrol stations and super markets cant cope with open bags so that has reduced sales a bit. Open bags are available for delivery or collection from most coal merchants.
The other loophole is that there is no prohibition on bulk sales, this exemption is intended for industrial use, including steam railways and other heritage uses. This is being misused by community groups buying a ton or two of loose house coal for use by individual households, all done to "protect the poorest households against the LATEST government scam to extract EVEN MORE money from them"
Traveler gangs are also selling house coal, bagged or otherwise, door to door. Generally of poor quality and of less than the claimed weight. This coal is often stolen shortly after delivery.
« Reply #131 on: January 12, 2022, 16:56:46 »
How much counts as bulk and how much would a coal-burning household expect to use each winter? My Polish in-laws would generally get through at least 2 tonnes a winter, but obviously winters are longer and colder there.
« Reply #132 on: January 12, 2022, 17:32:47 »
I am not aware of any exact minimum weight of delivery to be counted as "bulk" most coal merchants consider two tons or more as bulk, some will take orders for one ton.
For routine winter use to heat one room with a fire or stove, and partially warming nearby rooms by natural air circulation, I would expect about one ton per winter.
For whole house heating about twice that.
For a solid fuel AGA or Rayburn that heats bath water, cooks meals, and heats the house via radiators, several tons a winter.
House coal should not be used in closed domestic appliances due to the risk of explosions. It is for open fires, and large industrial boilers, including locomotives, under skilled control and with a good induced or forced draught.
« Reply #133 on: January 12, 2022, 18:20:32 »
I wonder if that counts as recycling nowadays…  Shocked
« Reply #134 on: January 12, 2022, 20:15:58 »
I sold my place with the open fire last March. I still see plenty of the big orange lorries used by my previous supplier, so I guess they are still trading. Their website is a little tight-lipped, so I looked elsewhere, and found:
The House Coal can be tipped into a suitable coal bunker or store and the empty bags taken away for recycling.
Alternatively the House Coal can remain in the bags. However, please note, that the bags will be cut open before our delivery partner leaves your premises, in order to comply with the new legislation.
So, not only are we saving the planet by these new regulations, we have also generated growth in the craft knife sector.
