« Reply #1425 on: October 13, 2016, 19:58:48 » |
Was a failed Class 70 on a Freightliner at Radley. After a bit of coaxing from the driver it managed to limp into Hinksey Yard and out of harms way.
« Reply #1426 on: October 14, 2016, 09:22:19 » |
More work for the delay attribution "Bean Counters"
« Reply #1427 on: October 17, 2016, 08:29:27 » |
.....new week, same old story Cancellations to services between Maidenhead and Slough Due to a fault with the signalling system between Maidenhead and Slough trains have to run at reduced speed on the line towards London Paddington. Train services running through these stations may be cancelled, delayed by up to 30 minutes or revised. Disruption is expected until 09:00 17/10.
« Reply #1428 on: October 17, 2016, 09:17:18 » |
At seven o'clock this morning there was an S+T bloke scrabbling around in the four foot on the Up Main at Slough West. Didn't fancy his job with trains continuing to run on the other three lines
« Reply #1429 on: October 17, 2016, 09:23:01 » |
Latest;
Due to a fault with the signalling system between Maidenhead and Slough the line towards London Paddington will be blocked. Train services running through these stations may be cancelled, delayed by up to 45 minutes or revised. Disruption is expected until 10:30 17/10. Customer Advice London bound passengers at Burnham and Taplow are advised to circulate via Maidenhead. Passengers for Taplow and Burnham are advised to circulate via Slough. Further Information This is due to an ongoing axle counter failure in the Slough area. Technicians need a blockage of one of the lines towards London Paddington to allow them to rectify issue. While this takes place there will be only 1 line able to accommodate trains into London and therefore alterations will take place to alleviate congestion through affected stations.
« Reply #1430 on: October 17, 2016, 09:43:07 » |
Thought something was wrong High Speed Train's (HST▸ )s going slow past house. Glad I'm not commuting any more!
« Last Edit: May 05, 2021, 16:30:00 by VickiS »
Jason
« Reply #1431 on: October 17, 2016, 11:41:58 » |
I was on 1L10 which ran at a glacial pace on the relief line from ~ Twyford to Slough. 35 minutes late into Paddington.
« Reply #1432 on: October 17, 2016, 16:06:28 » |
Do you qualify for a refund or are you not TV on 1L10?
johoare
« Reply #1433 on: October 17, 2016, 18:56:32 » |
And again:
Delays to services between Maidenhead and Slough Due to a fault with the signalling system between Maidenhead and Slough trains have to run at reduced speed on some lines towards London Paddington. Train services running through these stations may be delayed by up to 20 minutes. Disruption is expected until the end of the day. Last Updated:17/10/2016 18:50
« Reply #1434 on: October 17, 2016, 19:26:48 » |
1L10 is a high speed service originating from Swansea. Because GWR▸ are dragging in their heels over Delay Repay introduction there is currently no compensation for delays less than an hour for HSS▸ .
"Build a man a fire and he'll be warm for the rest of the day. Set a man on fire and he'll be warm for the rest of his life."
- Sir Terry Pratchett.
« Reply #1435 on: October 17, 2016, 19:50:57 » |
Day is ending as it started...........Delays to services between Maidenhead and Slough Due to a fault with the signalling system between Maidenhead and Slough trains have to run at reduced speed on all lines. Train services running through these stations may be delayed by up to 20 minutes. Disruption is expected until the end of the day.
a-driver
« Reply #1436 on: October 17, 2016, 20:02:03 » |
1L10 is a high speed service originating from Swansea. Because GWR▸ are dragging in their heels over Delay Repay introduction there is currently no compensation for delays less than an hour for HSS▸ . I don't think GWR should introduce Delay Repay until such times the DfT» and Network Rail can provide a reliable infrastructure. If they can't provide a reliable infrastructure then GWR should be compensated accordingly.
« Reply #1437 on: October 17, 2016, 20:04:32 » |
Are the defective axle counters and related equipment part of the "new and improved signalling that will bring about a faster and more reliable railway"
« Reply #1438 on: October 17, 2016, 20:39:16 » |
Unfortunately the computer way of observing the 'tail lamp' [a vital piece of railway safety equipment] and giving 'Train Out of Section' to the system. I assume in the case today it was considered most expedient to close the line and repair immediately rather than continue to send every express down the Up Main under caution. I got the feeling that the S+T man I saw this morning on his hands and knees in the four foot was looking for a damaged wire or connection.
« Last Edit: October 17, 2016, 20:47:15 by Oxonhutch »
