Travel & transport from BBC stories as at 12:35 02 May 2024
- Spectacular thunderstorms rumble across UK
* Russia blamed for GPS interference affecting flights in Europe
 18/05/24 - BRTA Westbury
22/05/24 - WWRUG / TransWilts update
17/08/24 - Bus to Imber
2nd May (1859)
Royal Albert Bridge opens
12:00 Oxford to London Paddington
13:00 Bristol Temple Meads to London Paddington
10:55 Paignton to London Paddington
12:35 London Paddington to Exeter St Davids
May 02, 2024, 12:49:23 *
[275] Vintage film - how valid are these issues today?
[81] Leven, Fife, Scotland, fast forward a month
[74] Train drivers "overwhelmingly white middle aged men"
[59] Visiting the pub on the way home.
[22] underground plans for Bristol update.
[15] Infrastructure problems in Thames Valley causing disruption el...
Pages: 1 ... 253 254 [255] 256 257 ... 307
Author Topic: Infrastructure problems in Thames Valley causing disruption elsewhere - ongoing, since Oct 2014  (Read 1267029 times)
« Reply #3810 on: September 19, 2022, 13:41:53 »
I wonder if there's a group within NR» (Network Rail - home page) saying "I told you - we should have replaced all that old headspan as soon as we could".
« Reply #3811 on: September 19, 2022, 14:04:25 »
I agree, and this would be a good time to announce replacement of at least the worst bits. Time to act quickly, partly to outmaneuver the NIMBYs.
This also reinforces my previously stated view that ALL new and refurbished electric trains should have either a small diesel engine or a battery sufficient to move the train, at a much reduced speed, when the wires come down. Or to power on board services if the train can not be moved.
One of the few merits of the failed IET (Intercity Express Train) project is the inclusion of a single diesel engine in the nominally electric trains.
GBM
« Reply #3812 on: September 19, 2022, 14:10:44 »
It seems a fairly frequent occurrence for the OHLE to fail, more so around Paddington.
Not aware of it being so much of an issue for other London termini.
From recent comments above, Paddington has older OHLE compared to other stations.
Whilst it would seem prudent to replace asap, that cost would have to be authorised by the DfT» (Department for Transport - about), and probably they are happy for Network Rail/GWR (Great Western Railway) to take the blame and not authorise additional expenditure.
« Reply #3813 on: September 19, 2022, 14:22:32 »
Yes, out as far as just beyond Hayes the electrification was done 'on the cheap' in the late 90s for the Heathrow Electrification and was virtually all headspan.
Several of the 'least worst bits' have been replaced over the years, usually around junctions where there is most risk.  You can see this here with the area concerned at between 9-10 minutes in:  https://www.youtube.com/watch?v=TMADOeBumAU I agree that all other areas should be replaced as soon as possible.  It is little use having very reliable OHLE, as we do, from 11 miles out of Paddington, if the first 11 miles are still susceptible to widespread damage in the event of failure.
Lines have now been re-energised between Reading and Stockley Bridge (between West Drayton and Hayes) so AIUI (as I understand it) an electric service can now operate as far as Slough/West Drayton from the Reading direction.
« Last Edit: September 19, 2022, 14:28:27 by IndustryInsider » Logged
« Reply #3814 on: September 19, 2022, 15:00:52 »
Obviously passengers wanting to get to Heathrow from Paddington are going to be frustrated.
National Rail say
Passengers travelling to / from Heathrow should use the Piccadilly Line.
Oh dear. TfL» (Transport for London - about) are saying
Piccadilly Line: Severe delays between Acton Town and Heathrow Airport / Uxbridge and between Arnos Grove and Cockfosters due to an earlier signal failure at Arsenal. Tickets are being accepted on London Buses and Great Northern. MINOR DELAYS on the rest of the line.
« Reply #3815 on: September 19, 2022, 15:39:17 »
Night Riviera sleeper cancelled in both directions.
GBM
« Reply #3816 on: September 19, 2022, 16:04:40 »
Don't understand that.
Entirely diesel hauled.
« Reply #3817 on: September 19, 2022, 16:14:32 »
Could well be due to staffing issues caused by the disruption.
« Reply #3818 on: September 19, 2022, 16:27:25 »
Or there is a need for a long duration possession tonight to repair the OLE (Overhead Line Equipment, more often "OHLE"), as it sounds like headspan construction are that was damaged an all lines block may be needed
« Reply #3819 on: September 19, 2022, 16:51:09 »
And just seen the "On This Day" story at the top of this page where 25 years ago today, the line was blocked for a horrifyingly different reason.
« Reply #3820 on: September 19, 2022, 17:38:28 »
Suspect GWR (Great Western Railway) will be picking up some pretty hefty hotel bills tonight.
« Reply #3821 on: September 19, 2022, 19:12:29 »
Suspect that GWR (Great Western Railway) will pass these costs on to Network Rail.
« Reply #3822 on: September 19, 2022, 19:16:46 »
AKA (also known as) the taxpayer, but that's a p***ing match for GWR & NR» (Network Rail - home page) to have later......main thing is that all customers are taken care of tonight.
Now suggesting that disruption will continue until "at least" 0900 tomorrow.
a-driver
« Reply #3823 on: September 19, 2022, 19:20:06 »
This mornings sleeper arrival into Paddington is still in the Paddington area!
« Reply #3824 on: September 19, 2022, 19:32:06 »
Which presumably means that it hasn't yet been cleaned from last night?
